| Subject |
Re: either siezed turbo or stuck wastegate, |
| Posted by |
xLoWx on July 15, 2008 at 10:09 AM |
This message has been viewed 475 times. |
| In Reply To |
either siezed turbo or stuck wastegate, posted by RedTTZ91(OK) on July 14, 2008 at 07:20 PM |
| Message |
:search. start the car and remove the outer intercooler hoses in the engine bay with it running, start with one side see what it does when you pull it off, then do the other, whichever side keeps running fine, thats the side the problem is on. Thanks for the help! I would think that I could remove the hose that goes to the throttle body correct? That would be the easiest one to get to. If not, which hose do I remove, and where is it? Thanks again!!!!
| Follow Ups |
Post a Followup |
