TwinTurbo.NET: Nissan 300ZX forum - Re: Lowside AC port access ?
Subject Re: Lowside AC port access ?
Posted by clulesssss on July 14, 2008 at 8:31 PM
  This message has been viewed 2077 times.
In Reply To Lowside AC port access ? posted by inski on July 14, 2008 at 02:24 PM
Message :The shrader valve to the low pressure line on the ac system is directly under the high pressure line at the firewall (next to the battery). How do I charge this pig? Or do I find an adapter for the small line?
You dont need an adapter to charge into the low side..I assume you have a guage set? just send the freon through the center port of the guage set, open the blue low side port and your set. plenty of room w/o the 134 adapter installed. if you like, you can put the adapter on the high side (near sight glass) for measurment purposes..nice to have a quick disconnect here..
