TwinTurbo.NET: Nissan 300ZX forum - Re: does the rotor fit tight over the wheel studs?
Subject Re: does the rotor fit tight over the wheel studs?
Posted by enthuZiast on July 13, 2008 at 1:46 PM
  This message has been viewed 107 times.
In Reply To does the rotor fit tight over the wheel studs? posted by Dane (Houston) on July 13, 2008 at 12:43 PM
Message I am using the centric rotors now.
I would think that if the holes are spaced wider, once the lug nuts are tightened down, there won't be any slop and movement.
I will check the shims for the pads.
I will most likely remove the 350z brake upgrade and go back to stock to further diagnose the problem.
This project should not have this much hassle.
Thank you
<<< Slow in & Fast out >>>
