TwinTurbo.NET: Nissan 300ZX forum - oil leak, what do i win?
Subject oil leak, what do i win?
Posted by gt300zxtt on July 13, 2008 at 4:45 AM
  This message has been viewed 137 times.
In Reply To Dr. Dr. when it rains it pours posted by 300ZMang on July 13, 2008 at 03:01 AM
Message check valve covers for leakage, then work your way down. hopefully the baffles are still intact if you still have stock pcv valves or plugged well if you have rerouted.
then start working your way down. we need pics of the upper side of the turbo as well as the side of the block.
is the oil supply line on top of the turbo clean? once you have ruled out the supply lines, then you can suspect turbo chra seal failure and check the compressor inlet and outlet pipes for oil. if it is inside these pipes, then replace turbo(s).
