TwinTurbo.NET: Nissan 300ZX forum - You can pull the ECU plug and test the injectors from
Subject You can pull the ECU plug and test the injectors from
Posted by Audioquest on July 12, 2008 at 10:58 PM
  This message has been viewed 150 times.
In Reply To I'm about to test my injectors now among other things posted by 300ZMang on July 12, 2008 at 03:53 PM
Message there which also validates your harness if it is suspect. If you find any bad ones, next step is still to pull the injector connector and check for corrosion and then test the injector again to see which is the culprit.
[ http://www.twinturbo.net/ttnetfaq/FAQpages/ecuharness.html ]
