TwinTurbo.NET: Nissan 300ZX forum - Re: Turbo Exhaust housing came Disconnected?!
Subject Re: Turbo Exhaust housing came Disconnected?!
Posted by txq45 on July 11, 2008 at 3:48 PM
  This message has been viewed 155 times.
In Reply To Turbo Exhaust housing came Disconnected?! posted by z32ryan on July 11, 2008 at 03:26 PM
Message If you've ever clocked a turbo (turbine/compressor) you would have had to loosen the bolts you speak of .. you may be able to get to them hopefully. If so just tighten them.. snug not tight...going 180 degrees to the next one to tighten. That's also where the seals start leaking.. Any oil there?
Most likely you'll have to take the turbo out to do the job correctly.
