TwinTurbo.NET: Nissan 300ZX forum - yep, I did the same
Subject yep, I did the same
Posted by aliaZ on July 11, 2008 at 12:51 PM
  This message has been viewed 209 times.
In Reply To or, get EPA certified (online, easy) and buy some R12 posted by bliZard on July 11, 2008 at 10:31 AM
Message although I ended up doing a retrofit anyways.
If you gut the TSV, it will be every bit as cold as an R-12 system. The problem is that you can run into issues with the evaporator freezing up, but that won't be too hard to fix
