TwinTurbo.NET: Nissan 300ZX forum - Pretty Simple
Subject Pretty Simple
Posted by DualZ (SF) on July 11, 2008 at 9:01 AM
  This message has been viewed 152 times.
In Reply To tech for replacing clutch master posted by WazTTed on July 11, 2008 at 07:54 AM
Message I recommend you get the slave as well. I thought i would be fine but after i replaced my master my slave went out the next day.
First drain the fluid from the bleed hole at the slave cylinder (lower right side of tranny).
Then remove the pin that holds the rod to the pedal.
Then put some rags below the master cyl to catch any drops of fluid.
Then get a FLARE NUT WRENCH (make sure you get one because if you strip the flare nut on the line you will be screwed and have to get or make a new one. Flare nuts tend to be hard to remove, thats why they make that tool!) and remove the hardline.
Then remove the 2 buts on to the booster and it will pop right out.
Then do the reverse to install and bleed (the clutch)
