TwinTurbo.NET: Nissan 300ZX forum - To combat that, when I did my buildup, I made sure
Subject To combat that, when I did my buildup, I made sure
Posted by pcproa on July 11, 2008 at 10:19 AM
  This message has been viewed 227 times.
In Reply To I'd get the 300 degree fuel rails instead posted by aliaZ on July 10, 2008 at 10:48 PM
Message the edges of the machined surfaces were smooth and clean, I put in the lower insulator and put a consistent bead of copper liquid gasket between the outside of the insulator and lower plenum seat. I waited just short of 24 hours for it to set and then pressure tested each lower plenum intake tract to 20psi without any leaks.
I can't say how it will hold up in the long run, but after 10,000KM since installation there are still no boost leaks.
I'm sure people will frown on this installation, but I also noticed when installing everything that the original Pintle styled lower insulator wrapped perfectly around the newer styled lower insulator and sat perfectly in the seat on the lower plenum.
1990 Nissan 300ZX
1982 Datsun 200SX
Cardomain website
