TwinTurbo.NET: Nissan 300ZX forum - Your CAS bolt you're talking about should be right
Subject Your CAS bolt you're talking about should be right
Posted by 300ZMang on July 10, 2008 at 12:40 PM
  This message has been viewed 141 times.
In Reply To Car runs worse when hot? Fuel? posted by Norincokid on July 10, 2008 at 09:39 AM
Message near the middle (from my experience) then set your timing to 15 degrees. Do what Audioquest said with the Coolant Temp Sensor.
Basically there are numerous things to look over here regarding your issue. Basic things like fuel & air filters, spark plugs, fuel pressure regulator and fuel dampener, all that fun stuff. About the psssshhht when releasing your gas cap, if it doesn't always do that, you simply need a new gas cap.
I'd also check your oxygen sensors, if they are close to toast they can make your car run like ass.
