TwinTurbo.NET: Nissan 300ZX forum - Pull the Coolant Temp Sensor connector and
Subject Pull the Coolant Temp Sensor connector and
Posted by Audioquest on July 10, 2008 at 11:14 AM
  This message has been viewed 176 times.
In Reply To Car runs worse when hot? Fuel? posted by Norincokid on July 10, 2008 at 09:39 AM
Message check if it's got green corrosion on it and if not test the sensor as if it's out of spec it will not run right. If you do find corrosion, pull all connectors with the spring clip and test the injectors resistance while they are off. Very common issue to have performance issues related to poor contact at critical components.
