TwinTurbo.NET: Nissan 300ZX forum - Car runs worse when hot? Fuel?
Subject Car runs worse when hot? Fuel?
Posted by Norincokid on July 10, 2008 at 9:39 AM
  This message has been viewed 178 times.
Message Hi
One by one, im nailing problems on my Z. Just had the clutch and rear main seal done.
Heres my next problem....
The car is sluggish all the time, but sometimes, when cold, it will put you in your seat pretty good for a NA. But not always.
Last night especially, on my way home from work (maybe 20 something miles) on the expressway I noticed the car was louder. It has loud mufflers but the tone was much deeper and louder. And it took a decent amount of throttle just to maintain 60mph. After a little more expressway run, the temp gauge kinda went up to about 3/4. This car usually doesnt go above 3/8.
When I got off the expressway it was very sluggish, but seemed to get its act together at higher RPMS. Its like it had no pull at all. The motor just made noise and slowly went up in speed.
I dunno if timing is an issue, my CAS is rotated all the way over (bolt is all the way on the right of the slot) and Im thinking maybe a fuel problem. Sometimes the pump sounds like its still running when I shut the car off, and taking the cap off relieves pressure and then its OK. Sometimes when I get gas, theres no PSST or nothing. Dunno if thats related.
Where should I look into first?
