TwinTurbo.NET: Nissan 300ZX forum - I think...
Subject I think...
Posted by ZCulture on July 09, 2008 at 9:39 PM
  This message has been viewed 175 times.
In Reply To At the risk of getting flamed, Boost jet question... posted by TTkeeper on July 09, 2008 at 03:38 PM
  1. Boost jets should not be causing this.
  2. You should remove them for better boost control by the EBC. Refer to [ http://www.ttzd.com/tech/ecu/ecu.html ] to locate them.
  3. My guess is that the EBC is not installed properly and it's not venting out boost pressure to the wastegates. You're getting 12psi now because the stock solenoids are gone which were letting you to go up to 15psi previously. This is assuming that the boost jets are there.
Take your Z to a shop that knows what they're doing. Excessive boost can be catastrophic.
