TwinTurbo.NET: Nissan 300ZX forum - Continous thicking sound can come from two sources
Subject Continous thicking sound can come from two sources
Posted by Attila on July 09, 2008 at 1:10 PM
  This message has been viewed 97 times.
In Reply To Help, just finished my timing belt change and now engine is posted by turbo1 on July 09, 2008 at 01:13 AM
Message 1. Injectors, what is normal. It is able to make noise, if one of them bad. Easy to diagnose with Power balance test.
2. Valve lifter. The noise will be decreased after the oil warm up.
If it is a strong and mechanical sound, then ask a mechanic to hear and judge.
Did you checked the position of the cylinders during the change? To not bend the valves above the 1st cylinder?
r.a.
