TwinTurbo.NET: Nissan 300ZX forum - Your IAA (Idle Air Adjusting) unit is not working
Subject Your IAA (Idle Air Adjusting) unit is not working
Posted by robo (sebring1970) on July 09, 2008 at 3:56 AM
  This message has been viewed 743 times.
In Reply To Low Idle when AC is on posted by l on July 08, 2008 at 11:57 PM
Message properly. The IAA unit is made up of the AAC (Auxilliary Air Control) valve, and the FICD solenoid valve. I would like someone to tell me what "FICD" stands for. The FICD solenoid valve compensates for changes in idle speed caused by the operation of the air compressor. That is most likely where your problem lies.
You could start with a simple spray cleaning with the unit still attached to the car. There is a write up on my website on this [ www.twinturbo.info ] > z32 > Idle Air Adjustment. Make sure all the clamps are tight and the connectors are clean and corrosion free.
If that doesn't work, your FICD solenoid is prob bad. Then you will have to remove the IAA unit to test and clean the components. You test the FICD solenoid valve after it is removed by applying 12V direct current (e.g. battery) and see if it makes a clicking sound.
See if the FICD plunger is sticking or if the spring is broken.
Get yourself a factory service manual (FSM). The diagnostics for all these parts are in there somewhere under the EF & EC section.
"Straight-line acceleration is probably the first aspect of automotive performance that any intelligent driver gets bored with." Peter Gregg
"We owe a lot to the dragsters. They always break something, figure out a way to beef up the part and the benefit trickles down." Robo
"Not everything that can be counted counts. Not everything that counts can be counted." Einstein
"And now my friend, the first-a rule of Italian driving, [Franco rips off his rear-view mirror and throws it out of the car] what's-a behind me is not important." Raul Julia, playing Franco Bertollini while driving a Ferrari Daytona in the movie Gumball Rally
