TwinTurbo.NET: Nissan 300ZX forum - did you change front calipers? get a helper to help pump
sawbonez
on July 08, 2008 at 9:35 PM
I need brake help, because stopping is good.
posted by puddlejumpinzx
on July 08, 2008 at 09:11 PM
the pedal. ensure resivoir is full, keep bleeding front brakes, takes time to get air out of new lines but you should see front brake fluid after 5-6 pumps of brake pedal along with bubbles
puddlejumpinzx
21:11:10 07/08/08
did you change front calipers? get a helper to help pump -
sawbonez
21:35:40 07/08/08
Didn't do any good
puddlejumpinzx
01:19:48 07/09/08
If you close the bleed nipple and remove the brakeline where
WoodmanZ
12:28:33 07/09/08
Re: If you close the bleed nipple and remove the brakeline where
puddlejumpinzx
15:08:13 07/09/08
Did you check to see
Tony@GZperformance
02:44:40 07/09/08
Yup
puddlejumpinzx
23:41:23 07/09/08
Ok I read over this a few time and I am not sure if I am
Tony@GZperformance
14:49:52 07/10/08
