TwinTurbo.NET: Nissan 300ZX forum - I need brake help, because stopping is good.
Subject I need brake help, because stopping is good.
Posted by puddlejumpinzx on July 08, 2008 at 9:11 PM
  This message has been viewed 109 times.
Message Ok, so here is the deal; I'm trying to bleed the brakes on the Z and I can only bleed the rears for some reason. I put stainless lines all the way around but yet I still can't get anything out of the fronts. Also, none of the calipers are seized up and I'm getting fluid coming out of the rear bleed port on the ABS module. The weird thing is that there is nothing coming out of the front bleed port on the ABS module and there is nothing coming out of the front calipers, even when I use my vacuum pump. When I do try to bleed anything from the front, it acts like it wants to suck air back into the system even when there is no pressure on the brake pedal. Any ideas?
