TwinTurbo.NET: Nissan 300ZX forum - A wire rubbing & shorting to ground would still be fused
Subject A wire rubbing & shorting to ground would still be fused
Posted by BobbyT on July 08, 2008 at 3:33 PM
  This message has been viewed 138 times.
In Reply To HUGE current draw, part 2 posted by Technomancer on July 08, 2008 at 12:43 PM
Message So you would've seen it stopped when you pulled all your fuses.
If your aftermarket alarm stuff isn't in plain sight in the engine bay, you could drop the panel under the steering wheel, and check behind the stereo, down by the ECU, under the panels behind the seats, and under the battery.
Might just have to pull your alternator to have it tested at a shop.
