| Message |
My dad's 95 NA has the ABS light on. The seatbelt light is also very dim when the belt is connected. I've done some searching about checking the codes for the ABS system. On a 95, there is no LED window as on the older models. According to the 94 FSM, you're supposed to be able to read the flashes on the dash ABS light after driving above 19mph for more than one minute, turning the car off, grounding the test connector next to the ECU diag plug, then turning the key on. We've done all of that and are getting no flashes, just a solid light. The ABS fuse is good, fluid level is good, the connectors are intact at the actuator and control unit, all of the sensors seem to be ok (although we didn't ohm them yet), but we can't figure out how to check the codes. Anyone else experience this?
Check out my profile on thecarspace.com! |
