TwinTurbo.NET: Nissan 300ZX forum - Use a short piece of PVC pipe the similar diameter
Audioquest
on July 04, 2008 at 5:55 PM
You are correct, I was changing the front seal.
posted by turbo1
on July 04, 2008 at 01:40 PM
as the outer metal portion of the seal, slide it over the crank end and tap the seal in evenly. That way it won't go in crooked.
Should I get a new crankshaft oil seal?
turbo1
03:52:45 07/04/08
The safest thing to do...
zeeway
05:28:48 07/04/08
Agree on getting a new seal, but why do you assume he
ThunderZ
11:03:22 07/04/08
turbo1
13:40:38 07/04/08
Use a short piece of PVC pipe the similar diameter -
Audioquest
17:55:30 07/04/08
Putting in the bottom in 1st then sliding your thumbs
ThunderZ
21:29:03 07/04/08
Here's what I used to install the front crankshaft seal...
WoodmanZ
02:11:40 07/05/08
