TwinTurbo.NET: Nissan 300ZX forum - should be wastegage boost - 7psi
Subject should be wastegage boost - 7psi
Posted by bliZard on July 03, 2008 at 7:44 AM
  This message has been viewed 181 times.
In Reply To No boost! posted by RedTTZ91(OK) on July 02, 2008 at 10:36 PM
Message your configuration should provide what you are thinking - wastegate only controlled boost at around 7psi. If you are getting no boost, I would think there is a massive boost leak. I don't know your history - is your boost gauge reading vacuum? If the engine runs decent, the leak must be on the atmosphere side of the MAS otherwise I wouldn't think it would run at all.
I suppose that it is also possible that there is a problem with the wastegates themselves - broken/bad springs or stuck open some how.
