TwinTurbo.NET: Nissan 300ZX forum - Re: The way I did it:
Subject Re: The way I did it:
Posted by not scared on July 03, 2008 at 12:46 AM
  This message has been viewed 140 times.
In Reply To The way I did it: posted by escturbo on July 02, 2008 at 08:49 PM
Message ok, im under the impression that you drilled that hole in the flat bracket that the sliding rail is bolted to? that bracket seems to be much stronger than the slide rail itself.
i looked at the rail, and the seat looking at how it would be mounted, and i noticed that to attach the seat i have to remove the slider from the base bracket, and thus i noticed it was a somewhat universal slider mounted on a bracket made for the z32. i just want to clarify before i go driling a hole in the wrong location.
thank you for your input, i will also contact charles about his method.
