TwinTurbo.NET: Nissan 300ZX forum - The way I did it:
Subject The way I did it:
Posted by escturbo on July 02, 2008 at 8:49 PM
  This message has been viewed 136 times.
In Reply To corbeau seat factory seat belt posted by not scared on July 02, 2008 at 06:38 PM
Message The Corbeau slider is flat and you have to mount the seatbelt to the slider itself. One problem this poses is that the seat belt receptacle will stay in one place as you move the seat around. The key is to mount the seat belt so it is in the perfect position where you would always sit.
So, mount the seat and slide it into the position you'll always be in. Then take the seat belt and mark on the slider where it needs to go. Take the seat back out, and mount the seat belt. There are different ways to mount it, but I took the easiest route and simply drilled a hole into the slider, bolted the seat belt receptacle in with grade 8 locking hardware from Lowe's(on the bottom of the slider), and bent the seat belt up into position. It works very well, and I have no fear that it won't hold just as well as stock in an accident.
You can try contacting Charles Park from Powertrix; he mounted his Corbeaus a different way. As for the harness and pictures, I can't help you with those.
