TwinTurbo.NET: Nissan 300ZX forum - Motor should be fine, as long as other maintenance
Subject Motor should be fine, as long as other maintenance
Posted by 300ZMang on July 02, 2008 at 7:35 AM
  This message has been viewed 117 times.
In Reply To Oil Leak and Clutch issues....related? posted by Norincokid on June 30, 2008 at 10:02 PM
Message has been kept up over the years.
The slippage of the clutch is mainly due to the leaking rear main seal. This will allow oil to cover the clutch and cause it to slip. However, your clutch is probably toast now, so good thing you bought a new one. Once you fix your PCV's and Rear Main along with the new clutch you should be good to go.
