TwinTurbo.NET: Nissan 300ZX forum - Codes can take a few cycles to register or sometimes if the
Subject Codes can take a few cycles to register or sometimes if the
Posted by Bernie (NoVA) on July 02, 2008 at 12:59 AM
  This message has been viewed 96 times.
In Reply To Speed sensor question posted by fozzy on June 29, 2008 at 09:33 AM
Message reading is in spec but non-responsive the system isn't smart enough to know there is a problem.
For example 02 sensors OK range is 0.01 to 0.99, if the sensor goes out of range it will likely toss a code, however if its stuck @ 0.45 the ECU sees it as in spec and OK but its not functioning correctly.
Bernie
