TwinTurbo.NET: Nissan 300ZX forum - Can a Code 34 (det. sensor) prevent engine from starting?
Subject Can a Code 34 (det. sensor) prevent engine from starting?
Posted by SPGZ on July 01, 2008 at 11:34 AM
  This message has been viewed 172 times.
Message I did a plenum pull and went to start the engine and it cranks but doesn't
start. I checked the codes and got a 11, 21, 34. I cleaned and greased the
cas sensor which eliminated the 11 and 21 but am still showing the 34 and
the engine still won't start. Would it be safe enough to bypass/relocate just
to get the engine running?
