then you need both with 98k on the car. There is a DIY writeup in the FAQ > AutoFAQ section of this site under PAGES if you want to tackle it your self. Not really too hard.Otherwise, for 4 OEM springs and struts you're looking at about $1,000 in parts alone and probably another $500 to $600 in labor. :-/ (You should be able to jack the car up and look at each strut. If one or more is leaking then it will be rusted or covered with a thick goo-like liquid.) Many folks go with KYB Adjustable struts and Eibach Springs along with a 300° camber kit as a less expensive option. Do a little research on this site on those terms for more info.
