TwinTurbo.NET: Nissan 300ZX forum - What clutches do not require break in?
Subject What clutches do not require break in?
Posted by ENDEE666 on June 30, 2008 at 10:40 PM
  This message has been viewed 199 times.
Message I recently did the clutch in my Audi when I put in the K04s. The 500 mile break in was hell, and I had to do it cause it was a Kevlar clutch.. And that was in my daily driver. To do a 500 mile break in with my Z would take months since I never use it. What clutches can just be run right away?? Need it to hold 500-600chp.
Thanks
-----------Fun Car-Z32TT-----------------------------
Dual pop, Borla, JWT ECU, GReddy PRofec-B II & Timer, ~16psi, JDM VG30DETT, 555's, RZT Turbos, Split DP's, Apexi SAFC, 2.5" Stainless Test Pipes, Underdrive Crank Pulley, 12.75" Front Rotors, slot&drilled all around wit AXXIS Ultimate Ceramic pads, Staggered 18's wrapped in Yokohama AVS ES100's- 265/35/18 & 235/40/18...
-----------Daily Car-2001 Audi A6 2.7t Sport 6spd------
APR ECU, K&N drop in, Darintake air box, 6 speed, sport pack (S4 motor, trans & brakes + 20mm lower & stiffer struts & stiffer sways)
