| I found a lot of information on search but couldn't quite find my answer. I'm testing for boost leaks, and couldn't get the intake over 2psi. rooting around I found a nipple on the underside of the throttle body hose that is not connected to anything or plugged. I have a profec B II controller installed by a dealer, and the same nipple on the driver's side connects to it's sending unit on the firewall. There are two more ports on the sending unit, one of which is connected to I believe both waste gate actuators, and the other port has no connection. For the passenger side nipple, should I: A. plug it B. Connect a hose to it and run it to the third port on the EBC sending unit, C. Connect it to something else. Many thanks.
