TwinTurbo.NET: Nissan 300ZX forum - 2nd. check my post above, similar issue >>
stockplayerz(nyc)
on June 29, 2008 at 11:47 PM
Just bc the battery shows strong voltage doesn't mean
posted by 300ZMang
on June 25, 2008 at 12:46 PM
battery voltage tested out fine, 12.5v off/ 14.x volts on. but a swap to a new battery fired her up nicely.
car won't start - advice?
John B
12:32:05 06/25/08
300ZMang
12:46:53 06/25/08
2nd. check my post above, similar issue >> -
stockplayerz(nyc)
23:47:11 06/29/08
12.8 is not low...12.65 is considered "perfect"
BobbyT
14:35:21 06/25/08
Have you checked the small solenoid wire
Audioquest
16:36:32 06/25/08
Have you tried bypassing the neutral safety switch?? Is the
WoodmanZ
16:39:43 06/25/08
Re: Have you tried bypassing the neutral safety switch?? Is the (n/m)
John B
18:59:34 06/25/08
Re: Re: bypassing the neutral safety switch?
John B
19:06:22 06/25/08
Use a jumper wire to connect the 2 sides together on the
WoodmanZ
19:23:34 06/25/08
John B
19:52:03 06/25/08
