TwinTurbo.NET: Nissan 300ZX forum - Fix the obvious leak up front and go from there. If you did
Subject Fix the obvious leak up front and go from there. If you did
Posted by Audioquest on June 29, 2008 at 11:28 PM
  This message has been viewed 119 times.
In Reply To An internal leak? lol posted by RedTTZ91(OK) on June 29, 2008 at 10:40 PM
Message the bypass the only place it could still leak is the ones that connect to the turbo. Use a long neck LED flashlight and check both sides if it is dripping on the turbo. A real slight leak back there will not hit the ground when the car is warm as it will evaporate off the turbo and once it cools it won't leak any more.
