TwinTurbo.NET: Nissan 300ZX forum - Pull the connector and clean it as well as check if the
Subject Pull the connector and clean it as well as check if the
Posted by Audioquest on June 29, 2008 at 6:58 PM
  This message has been viewed 122 times.
In Reply To Coolant temp gauge needle moves erratically. posted by jkcizbck on June 29, 2008 at 06:56 PM
Message tab on the sender is loose. Common problem the rivet that crimps it becomes loose. Carefully use a flat punch and tap it a bit to renew the contact.
