TwinTurbo.NET: Nissan 300ZX forum - I mean, If the timing belt is installed you can turn the
Subject I mean, If the timing belt is installed you can turn the
Posted by Dane (Houston) on June 29, 2008 at 12:43 AM
  This message has been viewed 181 times.
In Reply To You mean not if the timing belt is *not* installed (n/m) posted by WoodmanZ on June 28, 2008 at 11:04 PM
Message crank shaft with out damaging valves. If the timing belt was not in place he could spin piston into an opened valve.
So, "wouldn't bumping the ignition throw everything off?" No, not if the timing belt is installed.
Formerly SpecNATT (Houston)
cutforsig
