TwinTurbo.NET: Nissan 300ZX forum - This is one sign of a battery being low on charge.
Subject This is one sign of a battery being low on charge.
Posted by jzack on June 28, 2008 at 11:32 PM
  This message has been viewed 109 times.
In Reply To HELP! Starter? Alternator? >> posted by stockplayerz(nyc) on June 28, 2008 at 11:20 PM
Message Jumper the car and once it's idling properly measure the voltage across the battery terminals. If 13.5 volts or higher - alternator is probably OK but you probably need a new battery (or battery is just run down from some kind of drain -- light left on, etc).
It's also possilbe you may have a bad battery connection (corroided terminals?) or a bad battery to car ground connection. Two other things to check before replacing the battery.
