intermittent hesitation problems. To clean them you will need a pic set available at big box hardware store to remove the connector clips and scrape off the corrosion, and some electrical contact cleaner, then coat the connector with dielectric grease afterward.Connectors to check for the greenish corrosion are: TPS, 6 injectors, (coolant temp sensor - usually yellow or red on radiator pipe in front) (air regulator, AAC connector. - yellow and light blue connectors at right rear top of engine) Here's a link to some pics of various parts. [ http://www.z32photoguide.com/index.html ] Hope that helps. ps. O2 sensors could be culprit in failed emissions. There is an O2 sensor test you can perform to see if yours are working properly. Look in the TECH page of this site for "ecu self diagnostics" for info.
