TwinTurbo.NET: Nissan 300ZX forum - yep, bottle and assistant. remove the screen filter from
Subject yep, bottle and assistant. remove the screen filter from
Posted by sawbonez on June 28, 2008 at 8:02 PM
  This message has been viewed 166 times.
In Reply To What is best method then? Using a bottle and assistant? posted by WE350Z on June 28, 2008 at 06:21 PM
Message brake fluid resivoir, use bulb syringe to remove all old fluid from resivoir. fill with new fluid, bleed each caliper and abs in the correct order, making sure to refill the resivoir as needed until no bubbles and nice clean fluid flows from each bleed point. takes about 10 min total. i think the caliper bleed points are 11mm
