TwinTurbo.NET: Nissan 300ZX forum - Also, what kind of gaskets to use with block-off plate ?
TTkeeper
on June 28, 2008 at 3:08 PM
Sounds good...bought the EGR delete...one plug or 2 ?
posted by TTkeeper
on June 28, 2008 at 03:01 PM
Or do you make a permatex gasket ?
How much time does EGR delete add to a plenum pull ?
TTkeeper
12:28:38 06/28/08
the hardest part of the plenum pull is getting the EGR
robo (sebring1970)
13:14:57 06/28/08
TTkeeper
15:01:55 06/28/08
Also, what kind of gaskets to use with block-off plate ? -
TTkeeper
15:08:39 06/28/08
You can typically reuse the stock gaskets or use new ones.
23:07:48 06/28/08
The threaded plug goes into the drivers side exhaust
23:11:00 06/28/08
Do you also NEED to plug the exhaust manifold
ali300zx
15:15:45 06/28/08
Yes. (n/m)
23:08:11 06/28/08
why? cut and plug the EGR plenum tubes, disconnect
robo (sebring1970)
09:20:10 06/29/08
Confused....does EGR kit have everything you need ?
TTkeeper
11:03:21 06/29/08
you will need to fab some sort of plug for the EGR tubes
robo (sebring1970)
14:56:31 06/29/08
Would be nice if the EGR delete kit included tube plugs
TTkeeper
16:53:04 06/29/08
I don't really understand the motivation to remove it IF you
01:05:13 07/02/08
