TwinTurbo.NET: Nissan 300ZX forum - yes, ground the solenoids, JWT link inside
Subject yes, ground the solenoids, JWT link inside
Posted by Dane (Houston) on June 28, 2008 at 3:59 AM
  This message has been viewed 165 times.
In Reply To is there a way i can bypass the safety mode? posted by gumby on June 26, 2008 at 01:04 AM
Message [ http://www.jimwolftechnology.com/wolfpdf/Z32HIGH_BOOST_SWITCH.PDF ]
i had a TT with code 55 but ECU would not send out ground signal to saftey boost solenoid that are activated by a ground signal from the ECU as they have a constant batt voltage with IGN on from IGN fuse.
In sort clip and ground the wire at the ECU area on the harness side, not ECU side.
The vacuum and electrical circuit is designed with a logic that if there is an open, it will fail safe into saftey boost.
Formerly SpecNATT (Houston)
cutforsig
