TwinTurbo.NET: Nissan 300ZX forum - Thats is how i do them when my impact cant even do it
Dane (Houston)
on June 28, 2008 at 3:32 AM
If the strap wrench doesn't work, or you decide not to use
posted by WoodmanZ
on June 28, 2008 at 02:03 AM
good method just be safe.
Formerly SpecNATT (Houston)
trying to remove the crank pulley bolt w/o an impact wrench
turbo1
23:23:12 06/27/08
You can use the strap wrench. Just be careful. (n/m)
Spddracer
23:42:18 06/27/08
Re: trying to remove the crank pulley bolt w/o an impact wre
eyagel (Houston)
23:58:04 06/27/08
WoodmanZ
02:03:28 06/28/08
Re: If the strap wrench doesn't work, or you decide not to use
turbo1
02:49:37 06/28/08
not if the timing belt is installed
Dane (Houston)
03:35:27 06/28/08
You mean not if the timing belt is *not* installed (n/m)
WoodmanZ
23:04:39 06/28/08
I mean, If the timing belt is installed you can turn the
Dane (Houston)
00:43:22 06/29/08
woops, got confused there! Thats correct, as long as belt is
WoodmanZ
09:57:48 06/30/08
Thats is how i do them when my impact cant even do it -
Dane (Houston)
03:32:08 06/28/08
Be safe: put a piece of plywood between the pulley and
zellamay
15:15:50 06/28/08
got it opened!
turbo1
16:08:10 06/28/08
Did you put the park brake on? Also, have someone
Audioquest
09:22:05 06/29/08
