TwinTurbo.NET: Nissan 300ZX forum - I am not familiar with the resistor you are talking of but
Audioquest
on June 27, 2008 at 7:57 AM
Re: Re: One more thing...
posted by puddlejumpinzx
on June 26, 2008 at 02:01 PM
in general, resistors don't go bad very often. You could test it with a multimeter and see if it's in spec.
Have you tested the PTU?
Timing belt fiasco....
puddlejumpinzx
19:50:59 06/25/08
Re: Timing belt fiasco....
txq45
20:27:16 06/25/08
Yeah, and check for corrosion on cas connector (n/m)
jlag
21:02:10 06/25/08
1/2 a tooth out? Why, all you have to do is line up the gear
Audioquest
22:24:39 06/25/08
it is not possible to be a half a tooth off (n/m)
aliaZ
22:34:36 06/25/08
Re: (in addition to) Timing belt fiasco....
puddlejumpinzx
23:20:07 06/25/08
Try removing your crank angle sensor and then put it back
doug8867
20:13:13 06/26/08
I don't see how the belt is related to you problem. (n/m)
01:39:39 06/26/08
Re: I don't see how the belt is related to you problem.
puddlejumpinzx
11:18:50 06/26/08
Only thing I could guess that would relate the issues
Audioquest
11:22:19 06/26/08
Re: Only thing I could guess that would relate the issues
puddlejumpinzx
13:59:07 06/26/08
puddlejumpinzx
14:01:55 06/26/08
I am not familiar with the resistor you are talking of but -
Audioquest
07:57:40 06/27/08
puddlejumpinzx
00:32:09 06/27/08
Electrical contact cleaner and a pic work great for removing
doug8867
07:46:28 06/27/08
Good for you. The #1 cause of poor running. Pull all
Audioquest
08:53:39 06/27/08
