TwinTurbo.NET: Nissan 300ZX forum - Avc-r Boost Question
Subject Avc-r Boost Question
Posted by jrose10392 on June 26, 2008 at 7:19 PM
  This message has been viewed 144 times.
Message Im having an issue getting boost past factory even with my avc-r. My AVC-R is reading maximum of .54 boost. The factory gauge seems to point @ 7psi. I had it set to 70 with a duty cycle of 30. I have tried other settings and it doesnt seem to change. Prior to me pulling my motor and replacing the turbos everything was working fine. The turbos are a t/28. I decided to remove the factory solenoid and vacuum lines for a cleaner bay. I ran a straight vacuum line from the wastegate's directly to the com on the apexi solenoid. I have verified all hoses are not kinked torn etc. I did use new hose and there are no jets in the lines. I'm really looking to see what else should I be looking at? Is there a way to test the apexi solenoid?
