TwinTurbo.NET: Nissan 300ZX forum - Re: Re: One more thing...
puddlejumpinzx
on June 26, 2008 at 2:01 PM
Re: Only thing I could guess that would relate the issues
posted by puddlejumpinzx
on June 26, 2008 at 01:59 PM
I followed the wiring schematic for the common ground for the ignition coils and they are all intact so I'm still lost. Could the resistor at F3 be burned out causing the problem?
Timing belt fiasco....
puddlejumpinzx
19:50:59 06/25/08
Re: Timing belt fiasco....
txq45
20:27:16 06/25/08
Yeah, and check for corrosion on cas connector (n/m)
jlag
21:02:10 06/25/08
1/2 a tooth out? Why, all you have to do is line up the gear
Audioquest
22:24:39 06/25/08
it is not possible to be a half a tooth off (n/m)
aliaZ
22:34:36 06/25/08
Re: (in addition to) Timing belt fiasco....
puddlejumpinzx
23:20:07 06/25/08
Try removing your crank angle sensor and then put it back
doug8867
20:13:13 06/26/08
I don't see how the belt is related to you problem. (n/m)
01:39:39 06/26/08
Re: I don't see how the belt is related to you problem.
puddlejumpinzx
11:18:50 06/26/08
Audioquest
11:22:19 06/26/08
puddlejumpinzx
13:59:07 06/26/08
Re: Re: One more thing... -
puddlejumpinzx
14:01:55 06/26/08
I am not familiar with the resistor you are talking of but
Audioquest
07:57:40 06/27/08
puddlejumpinzx
00:32:09 06/27/08
Electrical contact cleaner and a pic work great for removing
doug8867
07:46:28 06/27/08
Good for you. The #1 cause of poor running. Pull all
Audioquest
08:53:39 06/27/08
