TwinTurbo.NET: Nissan 300ZX forum - Car not getting fuel
Subject Car not getting fuel
Posted by JCubed on June 26, 2008 at 10:57 AM
  This message has been viewed 236 times.
Message The other day after driving just fine I came home, shut the car off, then a couple hours later went to start the car and it started slowly idled lower then stalled out. I figure this was because it was using the remaining gas in the system. I figured my fuel pump was dead, so I installed a brand new one. Still no luck. I can manually make it pump fuel and it works great. So I unplugged the fuel filter and cranked, no fuel. I checked the fuses and relays and everything and can't find anything wrong. I'm also pulling no codes on consult. For fuel management I'm running my HKS VPC (map setup) and AFC NEO just like always. For some reason the car is just not pumping fuel. Is there a test I can do to check my fuel pump controler?
