TwinTurbo.NET: Nissan 300ZX forum - Re: Timing belt fiasco....
Subject Re: Timing belt fiasco....
Posted by txq45 on June 25, 2008 at 8:27 PM
  This message has been viewed 176 times.
In Reply To Timing belt fiasco.... posted by puddlejumpinzx on June 25, 2008 at 07:50 PM
Message CAS controls firing and fuel.. take cas out turn it and listen for clicks. You can also use a inductive timing light and watch for the light which will also tell you if there's ignition.. But sine it was running before you changed the timing belt the best bet from what you've said is the CAS.
Did you change out the cam gear oil seals?
