TwinTurbo.NET: Nissan 300ZX forum - Use a jumper wire to connect the 2 sides together on the
WoodmanZ
on June 25, 2008 at 7:23 PM
Re: Re: bypassing the neutral safety switch?
posted by John B
on June 25, 2008 at 07:06 PM
clutch pedal safety switch. If the car still doesn't start after that there is another safety switch on the transmission. Ground this one by jumping the green/yellow wire straight to the ground at one of the tranny mounts.
car won't start - advice?
John B
12:32:05 06/25/08
Just bc the battery shows strong voltage doesn't mean
300ZMang
12:46:53 06/25/08
2nd. check my post above, similar issue >>
stockplayerz(nyc)
23:47:11 06/29/08
12.8 is not low...12.65 is considered "perfect"
BobbyT
14:35:21 06/25/08
Have you checked the small solenoid wire
Audioquest
16:36:32 06/25/08
Have you tried bypassing the neutral safety switch?? Is the
WoodmanZ
16:39:43 06/25/08
Re: Have you tried bypassing the neutral safety switch?? Is the (n/m)
John B
18:59:34 06/25/08
John B
19:06:22 06/25/08
Use a jumper wire to connect the 2 sides together on the -
WoodmanZ
19:23:34 06/25/08
John B
19:52:03 06/25/08
