TwinTurbo.NET: Nissan 300ZX forum - Re: Won't rev passed 2500 RPMs - MAS? clogged cat? help
eyagel (Houston)
on June 25, 2008 at 12:11 AM
posted by 300ZMang
on June 24, 2008 at 09:20 PM
check fuel pressure
300ZMang
21:20:40 06/24/08
Sounds like a typical MAS signal issue.
ni[X]it
21:26:27 06/24/08
Took the harness off tonight to inspect.
300ZMang
21:45:44 06/24/08
If it's not the wiring, then it's the MAF itself.
Guapo
22:31:12 06/24/08
Thanks Guapo
300ZMang
22:40:30 06/24/08
Wiggle the harness with the car running and see what happns. (n/m)
Spddracer
22:40:49 06/24/08
OK
300ZMang
22:46:20 06/24/08
Then it's probably the MAF itself. (n/m)
BradZ (FL)
08:42:28 06/26/08
There is absolutely no reasoning behind that statement
Guapo
14:30:29 06/26/08
Looks goods? She looks 18, Check it anyway
Spddracer
20:33:34 06/26/08
Re: Won't rev passed 2500 RPMs - MAS? clogged cat? help -
eyagel (Houston)
00:11:23 06/25/08
Could this also be a bad TPS? (n/m)
300ZMang
08:57:49 06/25/08
MAF or the harness connector going to it. (n/m)
01:47:56 06/26/08
