TwinTurbo.NET: Nissan 300ZX forum - If the unit is turned on and the shaft seizes it will
Subject If the unit is turned on and the shaft seizes it will
Posted by Audioquest on June 24, 2008 at 10:23 PM
  This message has been viewed 82 times.
In Reply To Does the growl change with rpm ? posted by TTkeeper on June 24, 2008 at 11:48 AM
Message not freewheel, but it might if the clutch is ok and you don't engage it.
I changed mine when the rad was out and it was a 1/2 hour or so. You till need new o-rings for the pipes, which are both different sizes.
Also, you should get it evacuated (illegal to vent to atmosphere) before disconnecting and not leave it disconnected long to keep moisture out or it can ruin other parts in the system.
To recharge it you will have to buy compatible substitute or change it all over to R134.
I used Freeze 12 and it blows at least as cold as R-12 did.
