TwinTurbo.NET: Nissan 300ZX forum - Compression Testing -- How to add oil to cylinder???
Subject Compression Testing -- How to add oil to cylinder???
Posted by jzack on June 24, 2008 at 8:07 PM
  This message has been viewed 255 times.
Message Can someone advise on the best way to add a small amount of oil to the cylinder for a compression test? Maybe a straw pipette? My toolkit turkey baster doesn't really fit in the hole either.
Didn't want to just dump some into the spark plug guide - should be a better way?
FYI: My compression test as-is has been good and consistent across all the cylinders. Figured I'd give the oil test a try since I've never done any compression testing before...
