TwinTurbo.NET: Nissan 300ZX forum - Re: how would I check to see if one of my turbo seals is
Subject Re: how would I check to see if one of my turbo seals is
Posted by Ted (92TT) on June 24, 2008 at 11:36 AM
  This message has been viewed 79 times.
In Reply To how would I check to see if one of my turbo seals is posted by rmm299(nj) on June 23, 2008 at 06:50 PM
Message Clean the area up as much as possible. Make sure the turbo intake hoses are tight. Check for valve cover leaks or other leak sources that can drip toward the turbos. If you have significant oil in the boost tract, it will still smoke for a while. If it continues or gets worse, it's probably the turbo seal. Your stockers are 18 years old.
