TwinTurbo.NET: Nissan 300ZX forum - fuel pressure - still stumped
Subject fuel pressure - still stumped
Posted by ae300z on June 23, 2008 at 5:28 PM
  This message has been viewed 78 times.
Message The problem is the pressure jumps from 30 psi down to 12 psi and then back up again. This cycle will continue for several miles as long as I am in a vacuum mode. Occasionally the pressure will slightly build and once in a boost condition pressure jumps to around 60 psi and car runs great. I am guessing the voltage to the pump. Any help appreciated
code 55, replaced filter, regulator, damper, pump, fuel pump controller, prvc, vacuum hoses. Without starting the motor I can turn the iginition switch on and read 43psi, after 30 minutes I still have 30+ psi so I am guessing I do not have a major leak???
